Zum Hauptinhalt wechseln
Shark Vertex Pro IZ682H Brush Roller Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Replacement, Brush Roller: Schritt 1, Bild 1 von 1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
Abschluss
Tyree Brooks
486 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Mitglied von UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Mitglieder
Ein Kommentar
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
John Melo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 69
Insgesamt: 988
