Zum Hauptinhalt wechseln
Shark Vertex Pro IZ682H Post-Motor Filter Replacement
Was du brauchst
  1. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Battery: Schritt 1, Bild 1 von 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: Schritt 2, Bild 1 von 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: Schritt 3, Bild 1 von 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: Schritt 3, Bild 2 von 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: Schritt 4, Bild 1 von 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement: Schritt 4, Bild 2 von 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
  5. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: Schritt 5, Bild 1 von 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: Schritt 5, Bild 2 von 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: Schritt 5, Bild 3 von 3
    • You will find the post-motor filter in the device under where the dust cup was.
    • The post-motor filter can be easily removed now.
    • Clean the filter with soap and water.
    • Examine your filter for any damage, and if you find any you can buy a replacement on the Shark website.
Abschluss
Tyree Brooks
486 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Mitglied von UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 49
Insgesamt: 1,108
