Zum Hauptinhalt wechseln
Sharp Aquos Crystal USB Port Replacement
Was du brauchst
  1. Sharp Aquos Crystal USB Port Replacement, Back Panel: Schritt 1, Bild 1 von 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: Schritt 1, Bild 2 von 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal USB Port Replacement, USB Port: Schritt 2, Bild 1 von 2 Sharp Aquos Crystal USB Port Replacement, USB Port: Schritt 2, Bild 2 von 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal USB Port Replacement: Schritt 3, Bild 1 von 2 Sharp Aquos Crystal USB Port Replacement: Schritt 3, Bild 2 von 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal USB Port Replacement: Schritt 4, Bild 1 von 2 Sharp Aquos Crystal USB Port Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal USB Port Replacement: Schritt 5, Bild 1 von 3 Sharp Aquos Crystal USB Port Replacement: Schritt 5, Bild 2 von 3 Sharp Aquos Crystal USB Port Replacement: Schritt 5, Bild 3 von 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal USB Port Replacement: Schritt 6, Bild 1 von 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 7-4, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 2,130
