Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the TV face down on a flat smooth surface as to not scratch the screen. Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television. Lift the stand off the television.
    • Lift the stand off the television.
  3. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands.
    • Remove the two back panels by prying them out with your hands.
  4. Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge. Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Using your hands, gently lift and remove the back case of the television.
    • Using your hands, gently lift and remove the back case of the television.
  6. Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Remove the green and gray power connector from the side of the buttons panel at the top of the television. Remove the green/gray to orange/gray connector from the center of the circuit board.
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Robert Hobson
1.275 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 1-11, Amido Winter 2011 Mitglied von Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 37
Insgesamt: 7,034
