Zum Hauptinhalt wechseln
Sharp Aquos LC13B2UA Power Button Replacement
Was du brauchst
  1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: Schritt 1, Bild 1 von 2 Sharp Aquos LC13B2UA Power Button Replacement, Stand: Schritt 1, Bild 2 von 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 2, Bild 1 von 2 Sharp Aquos LC13B2UA Power Button Replacement: Schritt 2, Bild 2 von 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: Schritt 3, Bild 1 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: Schritt 3, Bild 2 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: Schritt 3, Bild 3 von 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 4, Bild 1 von 2 Sharp Aquos LC13B2UA Power Button Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: Schritt 6, Bild 1 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: Schritt 6, Bild 2 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 7, Bild 1 von 2 Sharp Aquos LC13B2UA Power Button Replacement: Schritt 7, Bild 2 von 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 8, Bild 1 von 2 Sharp Aquos LC13B2UA Power Button Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Power Button Replacement: Schritt 9, Bild 1 von 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: Schritt 10, Bild 1 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: Schritt 10, Bild 2 von 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: Schritt 10, Bild 3 von 3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
Abschluss
Robert Hobson
1.290 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 1-11, Amido Winter 2011 Mitglied von Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 6,505
