Einleitung
When doing this action, remember to power down the phone before disconnecting the battery. Also be careful not to completely remove the paper as it helps to keep electrical connections underneath. This repair may be needed if the battery in the phone is found to be faulty.
Was du brauchst
Remove case around battery using a T5 screwdriver to remove four 5mm silver screws.
Remove two 6mm T5 black screws.
Fast fertig!
Abschluss
