Zum Hauptinhalt wechseln
Sharp EL-520X Loose Circuit Board Wire Fix
Was du brauchst
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 1, Bild 1 von 1
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 2, Bild 1 von 2 Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 2, Bild 2 von 2
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 3, Bild 1 von 1
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 4, Bild 1 von 1
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 5, Bild 1 von 1
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 6, Bild 1 von 1
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 7, Bild 1 von 3 Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 7, Bild 2 von 3 Sharp EL-520X Loose Circuit Board Wire Fix: Schritt 7, Bild 3 von 3
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team M-6, Allen Summer 2023 Mitglied von York University, Team M-6, Allen Summer 2023
YORK-ALLEN-SU23SMG6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 34
Insgesamt: 294
