Einleitung
I am not responsible for anything in this article.
Was du brauchst
Remove - Back,microSD,battery,sim
Remove black rubber screw covers on back of display.
Remove 000 phillips screws (4) from top of display.
Remove 2 Torx t-7's by MicroSD slot.
After screws are removed you can detach screen.
Remove 4 additional 000 phillips screws from display.
Using some heat,spudger,frce pry away the broken display from the frame.
Use extreme caution the actual display is very fragile.
Remove connector for digitizer
replace connector with new digitizer and rebuild.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
