Einleitung
Removing the back panel is a prerequisite to any replacement or repair you need to do. When the back panel is removed the electronics and the speaker are visible and available to be removed or repaired.
Was du brauchst
Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
Fast fertig!
Abschluss
