Zum Hauptinhalt wechseln
Sharper Image SBT5002 Speaker Replacement
Was du brauchst
  1. Sharper Image SBT5002 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Sharper Image SBT5002 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Unplug the speaker before doing any work on it.
    • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
  2. Sharper Image SBT5002 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the back panel.
  3. Sharper Image SBT5002 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Remove the snap cable that connects the speaker to the circuit board.
  4. Sharper Image SBT5002 Speaker Replacement: Schritt 4, Bild 1 von 2 Sharper Image SBT5002 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
  5. Sharper Image SBT5002 Speaker Replacement: Schritt 5, Bild 1 von 2 Sharper Image SBT5002 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool or spudger to pry off the front panel.
  6. Sharper Image SBT5002 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
  7. Sharper Image SBT5002 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the defective speaker.
Abschluss
Linda Freund
235 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 544
