Einleitung
The user will learn how to:
- Remove the device from the case
- Completely tear down the device
- Locate the tripod nut
- Remove the tripod nut
Was du brauchst
Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
Locate the bottom of the device.
Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
Use the plastic opening tool to pry open the plastic panel from the top of the camera.
Locate the two screws on the top of the device.
Unscrew the two screws located on the back of the half that the tripod nut is located.
Once the screws are removed, the tripod nut can easily be removed.
