Zum Hauptinhalt wechseln
Shenzhou k680e Silicone Grease Replacement
Was du brauchst
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: Schritt 1, Bild 1 von 1
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: Schritt 2, Bild 1 von 1
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: Schritt 4, Bild 1 von 1
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: Schritt 5, Bild 1 von 1
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: Schritt 6, Bild 1 von 1
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: Schritt 7, Bild 1 von 1
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: Schritt 8, Bild 1 von 1
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: Schritt 9, Bild 1 von 2 Shenzhou k680e Silicone Grease Replacement: Schritt 9, Bild 2 von 2
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: Schritt 10, Bild 1 von 1
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: Schritt 11, Bild 1 von 1
    • Squeeze new thermal paste onto the chips.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Yizhen Qu
217 Reputation
1 Anleitung geschrieben
York University, Team S2-G22, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G22, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G22
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 651
