Zum Hauptinhalt wechseln
Einleitung
The Shift 6m from 2018 is an easy to open phone that has a user removable battery. Almost reaching repairability perfection by prioritizing screen repair and coming shipped with a mini screwdriver in the box for disassembly.
  1. Exterior reference shots. In the box you'll find a mini Torx T3 screwdriver. All the screws in the device are T3 and are identical. As on every shiftphone’s back we find a note at the bottom.
    • Exterior reference shots.
    • In the box you'll find a mini Torx T3 screwdriver. All the screws in the device are T3 and are identical.
    • As on every shiftphone’s back we find a note at the bottom.
  2. The 5.7" shift 6m on the left/bottom is only 1 mm thicker compared to the 5" shift 5.1 on the right/top. The 5.7" shift 6m on the left/bottom is only 1 mm thicker compared to the 5" shift 5.1 on the right/top.
    • The 5.7" shift 6m on the left/bottom is only 1 mm thicker compared to the 5" shift 5.1 on the right/top.
  3. The back cover and battery are both user removable and easy to replace—no tools needed. The back cover carries an NFC antenna. With its 16.3 Wh (4242 mAh @ 3.85 V) the shiftphone's battery surpasses the iPhone Xs Max (12.08 Wh) and even the Galaxy S10 (13.09 Wh), but falls behind the Mate 20 X (19.1 Wh).
    • The back cover and battery are both user removable and easy to replace—no tools needed.
    • The back cover carries an NFC antenna.
    • With its 16.3 Wh (4242 mAh @ 3.85 V) the shiftphone's battery surpasses the iPhone Xs Max (12.08 Wh) and even the Galaxy S10 (13.09 Wh), but falls behind the Mate 20 X (19.1 Wh).
  4. After 16! standard Torx T3 screws we pry the screen off the midframe and disconnect it from the motherboard. A small rubber gasket and the earpiece speaker are slightly glued to the screen. A small rubber gasket and the earpiece speaker are slightly glued to the screen.
    • After 16! standard Torx T3 screws we pry the screen off the midframe and disconnect it from the motherboard.
    • A small rubber gasket and the earpiece speaker are slightly glued to the screen.
  5. The rear camera can be disconnected and removed right away. Although the front facing camera is connected on top of the motherboard, a small adhesive strip holds it to the back. The power and volume button connector as well as the fingerprint sensor connector is inconveniently located on the back of the motherboard.
    • The rear camera can be disconnected and removed right away.
    • Although the front facing camera is connected on top of the motherboard, a small adhesive strip holds it to the back.
    • The power and volume button connector as well as the fingerprint sensor connector is inconveniently located on the back of the motherboard.
  6. Headphone jack, proximity sensor and front facing LED are soldered to the motherboard. On the other side there is a noise cancelling microphone and removable SIM card and SD card slots.
    • Headphone jack, proximity sensor and front facing LED are soldered to the motherboard.
    • On the other side there is a noise cancelling microphone and removable SIM card and SD card slots.
  7. The last parts to come out of the midframe are: The daughterboard board with the interconnect and antenna cable connected underneath.
    • The last parts to come out of the midframe are:
    • The daughterboard board with the interconnect and antenna cable connected underneath.
    • Soldered onto the board is the vibration motor and the USB-C port.
    • The fingerprint sensor and flash unit.
    • The power and volume buttons.
    • Surprisingly the top and bottom antennas can be removed from the frame with the bottom part carrying the loudspeaker.
  8. The shift 6m earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Battery and screen repairs are prioritized.
    • The shift 6m earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery and screen repairs are prioritized.
    • Throughout the phone only one type of screw head and length.
    • Manufacturer provides a few repair guides and a screwdriver is shipped with the phone.
    • Most components can be replaced separately.
    • Some cables are quite short and components overlap making repairs more complicated than necessary.
Ziellinie
3 weitere Nutzer haben diese Anleitung absolviert.
Tobias Isakeit
52.442 Reputation
117 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
101 Mitglieder
9.065 Anleitungen geschrieben
Past 48 hour data download
mamaofthree161719 - Antwort
View Statistical analysis
Would that work?
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 50
Letzte 7 Tage: 619
Letzte 30 Tage: 2,703
Insgesamt: 2,903
