Zum Hauptinhalt wechseln
Shop-Vac MC150A Motor Replacement
Was du brauchst
  1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: Schritt 1, Bild 1 von 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Motor Replacement, Remove the top cover: Schritt 2, Bild 1 von 2 Shop-Vac MC150A Motor Replacement, Remove the top cover: Schritt 2, Bild 2 von 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Motor Replacement: Schritt 3, Bild 1 von 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Motor Replacement: Schritt 4, Bild 1 von 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Motor Replacement, Disconnect the switch: Schritt 5, Bild 1 von 3 Shop-Vac MC150A Motor Replacement, Disconnect the switch: Schritt 5, Bild 2 von 3 Shop-Vac MC150A Motor Replacement, Disconnect the switch: Schritt 5, Bild 3 von 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: Schritt 6, Bild 1 von 2 Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: Schritt 6, Bild 2 von 2
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Motor Replacement: Schritt 7, Bild 1 von 2 Shop-Vac MC150A Motor Replacement: Schritt 7, Bild 2 von 2
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Motor Replacement: Schritt 8, Bild 1 von 1
    • Separate the clip from the green wire and transfer it to the replacement motor.
  9. Shop-Vac MC150A Motor Replacement, Motor: Schritt 9, Bild 1 von 2 Shop-Vac MC150A Motor Replacement, Motor: Schritt 9, Bild 2 von 2
    • Remove the motor bracket.
  10. Shop-Vac MC150A Motor Replacement: Schritt 10, Bild 1 von 1
    • Turn the part over to the other side.
    • Use the socket wrench remove the bolt securing the aluminum plate.
  11. Shop-Vac MC150A Motor Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the two Phillips head screws holding the cover to the motor.
    • After removing the cover to the motor, you can replace the motor.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Ngunlian
732 Reputation
5 Anleitungen geschrieben
IUPUI, Team 1-2, Baechle Spring 2016 Mitglied von IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Mitglieder
13 Anleitungen geschrieben
2 Kommentare
Where do I buy a new motor?????
Gerald Mikel - Antwort
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 72
Letzte 30 Tage: 213
Insgesamt: 28,478
