Einleitung
If you have a short or cut power cable you should replace it with a new one. This guide will help you through replacing the power cable attached to the vacuum.
Was du brauchst
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
Pull out and disconnect the four spade connectors from the switch module.
Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
During reassembly, be sure to reattach the green ground wire clip to the bracket.
Separate the clip from the green wire and transfer it to the replacement motor.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
How and where do I order a power cord? Just any power? Or a specific for shop vac.
