Zum Hauptinhalt wechseln
Shower Handle O-ring Replacement
Was du brauchst
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: Schritt 1, Bild 1 von 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
    Frag FixBot
  2. Shower Handle O-ring  Replacement: Schritt 2, Bild 1 von 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Frag FixBot
  3. Shower Handle O-ring  Replacement: Schritt 3, Bild 1 von 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    Frag FixBot
  4. Shower Handle O-ring  Replacement: Schritt 4, Bild 1 von 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
    Frag FixBot
  5. Shower Handle O-ring  Replacement: Schritt 5, Bild 1 von 2 Shower Handle O-ring  Replacement: Schritt 5, Bild 2 von 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
    Frag FixBot
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
Michigan Tech, Team 1-6, Lauer Spring 2016 Mitglied von Michigan Tech, Team 1-6, Lauer Spring 2016
MTU-LAUER-S16S1G6
1 Mitglied
1 Anleitung geschrieben
4 Kommentare zur Anleitung
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Antwort Teilen
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - Antwort Teilen
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 52
Letzte 30 Tage: 195
Insgesamt: 26,005
