Einleitung
For this repair you will learn how to replace a battery, one topic that will need to be understood is how to use a soldering iron. Being able to use that will have a big effect on replacing the battery.
Was du brauchst
Remove the suction pad by pulling the suction out of the slot that it is in.
Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
Pull apart the two halves.
Remove the four 5mm Phillips #1 screws from the motherboard.
Desolder the two wires connecting the battery tp the motherboard.
