Zum Hauptinhalt wechseln
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: Schritt 1, Bild 1 von 1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: Schritt 2, Bild 1 von 2 Shure SM58 Grille Replacement: Schritt 2, Bild 2 von 2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Abschluss
Follow the steps in reverse to install the new grille on the microphone.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
nat coll
642 Reputation
14 Anleitungen geschrieben
Cal Poly, Team 7-53, Forte Fall 2012 Mitglied von Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Mitglieder
20 Anleitungen geschrieben
2 Kommentare
Can you change the grilles of sm58 and sm86?
Jack - Antwort
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 10,020
