Zum Hauptinhalt wechseln
Shure SM58 XLR Microphone Connector Installation Replacement
Was du brauchst
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: Schritt 1, Bild 1 von 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: Schritt 2, Bild 1 von 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: Schritt 3, Bild 1 von 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Abschluss
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 weitere Personen haben diese Anleitung absolviert.
Ronald Lam
314 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-53, Forte Fall 2012 Mitglied von Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Mitglieder
20 Anleitungen geschrieben
7 Kommentare
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Antwort
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Antwort
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Antwort
Are the threads on your screw stripped?
Daniel Berger - Antwort
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 10,634
