Einleitung
Removing the battery.
Was du brauchst
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
Gently pry open button and remove button.
Do this for each of the 3 buttons remaining.
The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
Use the Torx 6 screwdriver to remove these 2 screws.
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
You can use your hands to simply pull apart the top casing from the bottom casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I have the battery out. Is their a way to check if it holds a charge? when I plugged charger into sidekick nothing lit up? is it a battery problem or a charge issue? The phone was never damaged. like the rest stop using it so died. figured battery is toast. this was a replacement tutorial. but doesn't show new battery going in to make sure you did correctly. I need the text messages and other data from my phone pretty bad. any help greatly appreciated.
Hi, I don’t have any Sidekick-specific advice here, but some for general data recovery from old phones like these. What I’ve done in the past is hunt down another donor phone that is functional, with a working charger, and use it to diagnose the issues on your phone, and make a working model with your motherboard.
