Zum Hauptinhalt wechseln
Sidekick II Thumbwheel Replacement
Was du brauchst
  1. Sidekick II Thumbwheel Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Thumbwheel Replacement: Schritt 2, Bild 1 von 2 Sidekick II Thumbwheel Replacement: Schritt 2, Bild 2 von 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Thumbwheel Replacement: Schritt 3, Bild 1 von 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Thumbwheel Replacement: Schritt 4, Bild 1 von 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Thumbwheel Replacement: Schritt 5, Bild 1 von 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Thumbwheel Replacement, Thumbwheel: Schritt 6, Bild 1 von 1
    • Remove 2 screws using the Torx 6 screwdriver.
  7. Sidekick II Thumbwheel Replacement: Schritt 7, Bild 1 von 1
    • The thumbwheel and casing will be loose, gently remove it.
Ziellinie
Cal Poly, Team 3-19, Maness Winter 2010 Mitglied von Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 2,159
