Einleitung
If your Singing Machine Shine Duets audio or power jacks are not functioning, use this guide as a means to replace it. If any parts which are removed in this guide have glue on them, use a metal scraping device to remove it. For our purposes, tweezers were sufficient.
Was du brauchst
Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
Use the opening tool or your hands to carefully pry open the now-loosened top panel.
Disconnect the red port on the board which holds all of the external plugs
Disconnect the white wires from the board.
Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
