Zum Hauptinhalt wechseln
Singing Machine Shine Duets LED Lights Replacement
Was du brauchst
  1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 1 von 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 2 von 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 3 von 3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets LED Lights Replacement: Schritt 2, Bild 1 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 2, Bild 2 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets LED Lights Replacement: Schritt 3, Bild 1 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 3, Bild 2 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 3, Bild 3 von 3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets LED Lights Replacement, LED Lights: Schritt 4, Bild 1 von 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: Schritt 4, Bild 2 von 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: Schritt 4, Bild 3 von 3
    • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
  5. Singing Machine Shine Duets LED Lights Replacement: Schritt 5, Bild 1 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 5, Bild 2 von 3 Singing Machine Shine Duets LED Lights Replacement: Schritt 5, Bild 3 von 3
    • Carefully remove the lightboard from the device, taking care not to damage any pins.
    • To reassemble, connect the pins on the lightboard to the motherboard.
Abschluss
Ethan Dodson
533 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 81
