Zum Hauptinhalt wechseln
Singing Machine Shine Duets Motherboard Replacement
Was du brauchst
  1. Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 1 von 3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 2 von 3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: Schritt 1, Bild 3 von 3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets Motherboard Replacement: Schritt 2, Bild 1 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 2, Bild 2 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets Motherboard Replacement: Schritt 3, Bild 1 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 3, Bild 2 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • The motherboard is located right behind the control buttons.
  5. Singing Machine Shine Duets Motherboard Replacement: Schritt 5, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two screws holding the LED board in place.
  6. Singing Machine Shine Duets Motherboard Replacement: Schritt 6, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove both LED boards from their pins.
  7. Singing Machine Shine Duets Motherboard Replacement: Schritt 7, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Detach the white cable from its connector on the motherboard.
  8. Singing Machine Shine Duets Motherboard Replacement: Schritt 8, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Carefully disconnect this red-and-black wire from the motherboard.
  9. Singing Machine Shine Duets Motherboard Replacement: Schritt 9, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the thicker red-and-black wire from its socket on the motherboard.
  10. Singing Machine Shine Duets Motherboard Replacement: Schritt 10, Bild 1 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 10, Bild 2 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the red port on the board which holds all of the external plugs
    • Disconnect the white wires from the board.
  11. Singing Machine Shine Duets Motherboard Replacement: Schritt 11, Bild 1 von 2 Singing Machine Shine Duets Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
  12. Singing Machine Shine Duets Motherboard Replacement: Schritt 12, Bild 1 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 12, Bild 2 von 3 Singing Machine Shine Duets Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the motherboard from the shell.
Abschluss
Ethan Dodson
533 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 204
