Einleitung
If your Singing Machine Shine Duets motherboard is malfunctioning for any reason, use this guide to replace it. Your device may require the removal of glue or wax on the motherboard, so have a thin metal scraping device at the ready. We used tweezers for ours. If a piece we removed has glue on it, you will need to scrape it off.
Was du brauchst
Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
Use the opening tool or your hands to carefully pry open the now-loosened top panel.
Disconnect the red port on the board which holds all of the external plugs
Disconnect the white wires from the board.
Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
