Zum Hauptinhalt wechseln
Sink Drain Pop-Up Stopper Replacement
Was du brauchst
  1. Sink Drain Pop-Up Stopper Replacement, Pop-Up Stopper: Schritt 1, Bild 1 von 2 Sink Drain Pop-Up Stopper Replacement, Pop-Up Stopper: Schritt 1, Bild 2 von 2
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Sink Drain Pop-Up Stopper Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the pivot rod from the center pop-up extension.
  3. Sink Drain Pop-Up Stopper Replacement: Schritt 3, Bild 1 von 2 Sink Drain Pop-Up Stopper Replacement: Schritt 3, Bild 2 von 2
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Sink Drain Pop-Up Stopper Replacement: Schritt 4, Bild 1 von 3 Sink Drain Pop-Up Stopper Replacement: Schritt 4, Bild 2 von 3 Sink Drain Pop-Up Stopper Replacement: Schritt 4, Bild 3 von 3
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Sink Drain Pop-Up Stopper Replacement: Schritt 5, Bild 1 von 2 Sink Drain Pop-Up Stopper Replacement: Schritt 5, Bild 2 von 2
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Sink Drain Pop-Up Stopper Replacement: Schritt 6, Bild 1 von 2 Sink Drain Pop-Up Stopper Replacement: Schritt 6, Bild 2 von 2
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 160
Insgesamt: 2,355
