Zum Hauptinhalt wechseln
Sirius Stiletto 100 Volume Button Replacement
Was du brauchst
  1. Sirius Stiletto 100 Volume Button Replacement, Front Cover: Schritt 1, Bild 1 von 2 Sirius Stiletto 100 Volume Button Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Sirius Stiletto 100 Volume Button Replacement: Schritt 2, Bild 1 von 2 Sirius Stiletto 100 Volume Button Replacement: Schritt 2, Bild 2 von 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Sirius Stiletto 100 Volume Button Replacement: Schritt 3, Bild 1 von 3 Sirius Stiletto 100 Volume Button Replacement: Schritt 3, Bild 2 von 3 Sirius Stiletto 100 Volume Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Sirius Stiletto 100 Volume Button Replacement, Circuit Board: Schritt 4, Bild 1 von 1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Sirius Stiletto 100 Volume Button Replacement: Schritt 5, Bild 1 von 2 Sirius Stiletto 100 Volume Button Replacement: Schritt 5, Bild 2 von 2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Sirius Stiletto 100 Volume Button Replacement: Schritt 6, Bild 1 von 1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  7. Sirius Stiletto 100 Volume Button Replacement, Volume Button: Schritt 7, Bild 1 von 1
    • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
  8. Sirius Stiletto 100 Volume Button Replacement: Schritt 8, Bild 1 von 1
    • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
  9. Sirius Stiletto 100 Volume Button Replacement: Schritt 9, Bild 1 von 1
    • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
    • The volume button will pop out.
  10. Sirius Stiletto 100 Volume Button Replacement: Schritt 10, Bild 1 von 1
    • Remove the volume button from the device.
  11. Sirius Stiletto 100 Volume Button Replacement: Schritt 11, Bild 1 von 1
    • Slide the new volume button into the slot for the volume button.
    • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
  12. Sirius Stiletto 100 Volume Button Replacement: Schritt 12, Bild 1 von 1
    • Push down on the volume button to snap it back into the case.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Morgan McDougald
71 Reputation
3 Anleitungen geschrieben
Clemson, Team 2-1, Benson Spring 2012 Mitglied von Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,343
