Zum Hauptinhalt wechseln
Sirius Stiletto 2 Front Cover Replacement
Was du brauchst
  1. Sirius Stiletto 2 Front Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 Front Cover Replacement: Schritt 2, Bild 1 von 2 Sirius Stiletto 2 Front Cover Replacement: Schritt 2, Bild 2 von 2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 Front Cover Replacement, Front Cover: Schritt 3, Bild 1 von 1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 Front Cover Replacement: Schritt 4, Bild 1 von 2 Sirius Stiletto 2 Front Cover Replacement: Schritt 4, Bild 2 von 2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
Abschluss
Benjamin Her
555 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 6-6, Brown Winter 2015 Mitglied von USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 295
