Einleitung
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
Was du brauchst
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
Start by using a plastic opening tool to loosen the front cover from the sides.
Work your way to the bottom of the cover then the top.
Carefully pry the front cover off.
Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
