Einleitung
The scroll wheels allows user interact with the device. A scroll wheel that does not work will not allow users to play music or access other features on the device.
Was du brauchst
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
Start by using a plastic opening tool to loosen the front cover from the sides.
Work your way to the bottom of the cover then the top.
Carefully pry the front cover off.
Isolate the scroll wheel assembly
Gently pry the four metal tabs outwards, away from the scroll pad.
Once the scroll pad has been released, be careful not to drop the center button. This may damage the spring.
