Einleitung
A crack in the casing of the device can cause further problems so it is necessary to change the casing. In this guide we will be showing you how to change the casing on the the SiriusXM Onyx Plus.
Was du brauchst
Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
Fast fertig!
Abschluss
