Einleitung
The LED screen is attached to the motherboard inside the casing. This guide will show how to detach the screen from the motherboard for replacement.
Was du brauchst
Take the iFixit opening tool and place it between the crevice as shown.
Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
Remove the plastic case in front of the socket using the spudger.
Hold the screen and gently pull in the direction of the cable to separate screen from the socket.
