Zum Hauptinhalt wechseln
Skateboard Trucks Replacement
Was du brauchst
  1. Skateboard Trucks Replacement, Trucks: Schritt 1, Bild 1 von 2 Skateboard Trucks Replacement, Trucks: Schritt 1, Bild 2 von 2
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Trucks Replacement: Schritt 2, Bild 1 von 1
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Trucks Replacement: Schritt 3, Bild 1 von 1
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Trucks Replacement: Schritt 4, Bild 1 von 1
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
Abschluss
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 6-32, Regan Fall 2012 Mitglied von Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 13,613
