Einleitung
I will demonstrate how to repair the torn lining of a piece of clothing using simple methods and accessible tools. This fix will show you how to replace the inner lining of this garment in a few non-tedious steps.
The inner lining of a skirt is a very essential part and caters to a diverse range of needs, from the privacy and conservation of the body to those that desire it, to warmth, personal style choices and sustainability practices.
Was du brauchst
Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
Gently insert the threaded needle. Be careful not to prick your finger.
Push through the skirt fabric from below.
Pull the needle all the way out to form a stitch.
Continue with step 3 until you create stitches around the whole waistband of your skirt.
Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
Try it on!
Eine weitere Person hat diese Anleitung absolviert.
