Zum Hauptinhalt wechseln
SkullCandy Hesh Auxiliary Cable Replacement
Was du brauchst
  1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: Schritt 1, Bild 1 von 1
    • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
  2. SkullCandy Hesh Auxiliary Cable Replacement: Schritt 2, Bild 1 von 1
    • Using wire cutters, cut the auxiliary cable at the determined damaged area.
    • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
  3. SkullCandy Hesh Auxiliary Cable Replacement: Schritt 3, Bild 1 von 2 SkullCandy Hesh Auxiliary Cable Replacement: Schritt 3, Bild 2 von 2
    • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
  4. SkullCandy Hesh Auxiliary Cable Replacement: Schritt 4, Bild 1 von 1
    • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
    • Twist together the same colored wires from the device cable and the new cable.
  5. SkullCandy Hesh Auxiliary Cable Replacement: Schritt 5, Bild 1 von 1
    • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
  6. SkullCandy Hesh Auxiliary Cable Replacement: Schritt 6, Bild 1 von 1
    • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
Abschluss
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
247 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,014
