Zum Hauptinhalt wechseln
SkullCandy Hesh Size Adjuster Replacement
Was du brauchst
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: Schritt 1, Bild 1 von 2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: Schritt 1, Bild 2 von 2
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: Schritt 3, Bild 1 von 1
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: Schritt 4, Bild 1 von 2 SkullCandy Hesh Size Adjuster Replacement: Schritt 4, Bild 2 von 2
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: Schritt 5, Bild 1 von 1
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: Schritt 6, Bild 1 von 1
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
Abschluss
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
247 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 821
