Einleitung
If your Skullcandy Air Raid will not maintain power even after charging, it may be time to replace the battery.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Gently pull the sides of the front plate outwards from the device.
Pull up on the front plate to remove it from the device.
Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
Using a plastic opening tool, pry the button motherboard to detach it from the device.
Pull the black ribbon cord attachment away from the motherboard.
Pull on the cable until it releases from the back of the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
Lift off the back panel.
Pull on the ribbon cable that connects the battery to the motherboard until the connector releases.
Pull battery straight out until it is completely out of device.
5 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
Hi, my name is Alex, and i have the same problem. The battery does not work anymore, but i don't know where can i find a replacement, and what is the its name. Or mabe something similar? I live in Romania so i need mabe an international online store to buy it. Thank you! My email is stanciualex_e@ yahoo.com
What is the type of battery?
