Einleitung
This disassembly includes the button panel and button motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Gently pull the sides of the front plate outwards from the device.
Pull up on the front plate to remove it from the device.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
Lift the button panel.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
First, pull on the black attachment to disconnect it from the metal piece.
Release the cable from the back of the motherboard.
2 weitere Nutzer haben diese Anleitung absolviert.
