Einleitung
You will use this guide to replace the folding hinge in a Skullcandy Crusher Wireless headphones. Replacement folding hinges can be bought online or taken from another Skullcandy Crusher Wireless headphone.
Was du brauchst
Extend and fold the hinge of the headphones you are trying to replace.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
