Zum Hauptinhalt wechseln
Skullcandy Lowrider Wiring Repair
Was du brauchst
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: Schritt 1, Bild 1 von 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: Schritt 1, Bild 2 von 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: Schritt 1, Bild 3 von 3
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: Schritt 2, Bild 1 von 2 Skullcandy Lowrider Wiring Repair: Schritt 2, Bild 2 von 2
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: Schritt 3, Bild 1 von 3 Skullcandy Lowrider Wiring Repair: Schritt 3, Bild 2 von 3 Skullcandy Lowrider Wiring Repair: Schritt 3, Bild 3 von 3
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: Schritt 4, Bild 1 von 1
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
Abschluss
Ryley
273 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015
USFSM-STEWART-W15S1G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 626
