Zum Hauptinhalt wechseln
Skullcandy Mix Master DJ Mylar Driver Replacement
Was du brauchst
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: Schritt 1, Bild 1 von 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: Schritt 1, Bild 2 von 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: Schritt 1, Bild 3 von 3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 2, Bild 1 von 1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 3, Bild 1 von 2 Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 3, Bild 2 von 2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 4, Bild 1 von 2 Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 4, Bild 2 von 2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 5, Bild 1 von 2 Skullcandy Mix Master DJ Mylar Driver Replacement: Schritt 5, Bild 2 von 2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-3, Shastany Spring 2015 Mitglied von UMass Dartmouth, Team 1-3, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,495
