Zum Hauptinhalt wechseln
Sky Thunder HD 8500WH Gear Replacement
Was du brauchst
  1. Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: Schritt 1, Bild 1 von 3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: Schritt 1, Bild 2 von 3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: Schritt 1, Bild 3 von 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Gear Replacement, Lockstitch: Schritt 2, Bild 1 von 2 Sky Thunder HD 8500WH Gear Replacement, Lockstitch: Schritt 2, Bild 2 von 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: Schritt 3, Bild 1 von 3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: Schritt 3, Bild 2 von 3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: Schritt 3, Bild 3 von 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Gear Replacement: Schritt 4, Bild 1 von 2 Sky Thunder HD 8500WH Gear Replacement: Schritt 4, Bild 2 von 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Gear Replacement, Gear: Schritt 5, Bild 1 von 2 Sky Thunder HD 8500WH Gear Replacement, Gear: Schritt 5, Bild 2 von 2
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Gear Replacement: Schritt 6, Bild 1 von 2 Sky Thunder HD 8500WH Gear Replacement: Schritt 6, Bild 2 von 2
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Gear Replacement: Schritt 7, Bild 1 von 1
    • Pull the gear out from the bottom of the holding mechanism.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 142
