Zum Hauptinhalt wechseln
Sky Thunder HD 8500WH Lower and Upper Body Replacement
Was du brauchst
  1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: Schritt 1, Bild 1 von 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: Schritt 1, Bild 2 von 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: Schritt 1, Bild 3 von 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: Schritt 2, Bild 1 von 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: Schritt 2, Bild 2 von 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: Schritt 3, Bild 1 von 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: Schritt 3, Bild 2 von 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: Schritt 3, Bild 3 von 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Lower and Upper Body Replacement: Schritt 4, Bild 1 von 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement: Schritt 4, Bild 2 von 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 125
