Zum Hauptinhalt wechseln
Skytex SP728 Antenna Replacement
Was du brauchst
  1. Skytex SP728 Antenna Replacement, Case: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Antenna Replacement: Schritt 2, Bild 1 von 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Antenna Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Antenna Replacement: Schritt 4, Bild 1 von 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Antenna Replacement, Antenna: Schritt 5, Bild 1 von 1
    • Remove the case and open the device
  6. Skytex SP728 Antenna Replacement: Schritt 6, Bild 1 von 1
    • Remove the black tapes
  7. Skytex SP728 Antenna Replacement: Schritt 7, Bild 1 von 1
    • Use the soldering station and remove soldered connections to the antenna wires.
    • Now replace the antenna.
    • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 5-1, Brown Winter 2015 Mitglied von USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 98
