Einleitung
This repair guide will walk through the primary steps of replacing the antenna in Skytex SP728.
Was du brauchst
Make sure the device is powered off
Rotate the device so the ports and screws face you
Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
Use the soldering station and remove soldered connections to the antenna wires.
Now replace the antenna.
Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
