Einleitung
How to remove the back case of the tablet.
Was du brauchst
Make sure the device is powered off
Rotate the device so the ports and screws face you
Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
To reassemble your device with a new case, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
