Zum Hauptinhalt wechseln
Skytex SP728 Speakers Replacement
Was du brauchst
  1. Skytex SP728 Speakers Replacement, Case: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: Schritt 7, Bild 1 von 1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Nelson
213 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-1, Brown Winter 2015 Mitglied von USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 97
