Was du brauchst
Make sure the device is powered off
Rotate the device so the ports and screws face you
Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
