Einleitung
By following this guide one is able to access the inside of the Skytex Skypad Alpha 2 tablet in four steps. These steps include locating and unscrewing the screws that are found at the sides of the tablet and using a plastic opening tool to separate the back case from the tablet and replace if necessary.
Was du brauchst
Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
