Zum Hauptinhalt wechseln
Skytex Skypad Alpha 2 Battery Replacement
Was du brauchst
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: Schritt 2, Bild 1 von 2 Skytex Skypad Alpha 2 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: Schritt 4, Bild 1 von 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team 6-5, Williams Fall 2015 Mitglied von Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 782
